Anybody have a factory 24V tailpipe?
Air Line fittings
243: FWIW, I called M&D (on N. Shepherd) and they didn't have any. There is another place though...
High Performance Diesel (281)345-4224
You may have other sources. M&D suggested checking the bone yards, but had no suggestions.
HTH.
Duane
exh
sent ya a PM
I should have looked at the post didnt show any replys from the engine/drive train forum
simular senaro as Chipstien reply
good luck
Guy
I have the stock 2002 muffler/resonator assembly, but no tailpipe! Those LSTDR vultures grabbed that thing before we even had the Jardine 4" system completely bolted up on my truck. ;) :D
Rusty
David- I'll be installing my 4" system @ the bomb session later this month. If you can use my 3" tailpipe (12 valve, 2wd long bed) you're welcome to it.
Thanks Bill, but I'll wait until I find a 24V pipe so that I use the factory hangers. Will you be adding more fuel to go along with the 4" exhaust?
He will, he just don't know it yet. :D
You guys keep him near the back of the truck while I break into his pump and do a little tinkering. :-laf
243,
I have only the section that goes over the rear axle and the tailpipe tip.
My truck is a '98. 5 3500 2wd. Let me know if you can use it.
Merrick Cummings Jr
will have to check.............
I should have mine left over from my stack job. It is down at my cousin's shop. It came off of my 99 24V cab/chassis long wheel base. Not sure if it is the exact pipe you are looking for. If it is you are welcome to it. Let me know and I can take some measurements off of it to see if it will work. I am located about an hour north of Lake Charles.
Todd
All, thanks a lot for all the replies. I will see if I can work something out with Merrick... .
... I will email or shoot you a PM.
243, I have complete exh. system off my '01 3500 2WD,LWB. Very few miles too on it too but it is three (3) pieces due to 2 saw cuts. If you want it, give me a call at home.
Howard
