Anybody running a HTT Sled Puller 66 on a HOT 12V
Mach 4s in, DD2s out-- pretty impressed!
Oil and Oil filter
Do we have any members with "HOT" 12V's running the HTT Sled Puller 66? Smokin Monster is the only one I've seen, just wondering if there are anymore? :confused:
Sorry, I don't have one but what is "HOT"? TIA
What do you consider hot?? EGTs or HP, few pulls back I saw 1780 on the pyro. I think my truck has a lot of potential for being a hot truck, but I just have to figure all of the quirks out and how to make it run right. Right now I am playing with wastegate and drive pressures trying to get the EGT's down.
Sorry guys I figured everyone would know I meant just running a LARGE amount of fuel when I said "HOT". I'm wondering how a HTT SP66 spools on a 12V that has a large amount of fuel, like #0 plate, Laser Cut DV's, & 370's. Talked to Pual and he said it would definately be under 2000PRM's, but could tell me quite where it would start to spool. Smokin Monster says his starts to spool @ 1600-1700RPM's. Just looking for some additional input by other owners. Thanks!
Well like I said i would think that I could have an exhorbent amout of fuel. My pump is capable of 650cc and Mr. Adkins said" 650cc is a ton of fuel" compared to stock 180cc pump of 182cc. You don't necessarily need DV's to get it either talk to Joe Donnelly, I think he made his 800HP run on 181, so to answer your question, My special HTT sledpuller 66, I have a low stall stator from Goerend. Foot hard on Brake, roll into the throttle, engine jumps right to 1300 or so, then slowly roll on the accelerator, I can almost hold it to 2000 RPM, then it just over powers the brakes. At the 1900 or so I am right about 15-18 psi or so. I think the these chargers spool very well. I still am putting out a pretty dark cloud running down the track at about 50 psi of boost. So I would say the charger lights pretty well about 1500-1600. If you have any questions feel free to ask.
by the way I knew what you meant by hot, but need to quantify it. Some guys think that 370's and DV are hot. I think that would be a warm setup. Hot is bigger than 370's and some pump work done. Like I said i have my 0 plate about a 1/3 of the way forward, and I can still block out city blocks and at 50 psi I still have adequate fuel, I would love to slide my plate the rest of the way forward, but I don't think I have the air to do it. Mr Adkins did an excellent job on the pump he worked for me.
If I knew of a place to send it to I would have, but I called around and he was the best price and so far it has plenty of fuel.
Forrest said:
:-laf :-laf
:D
Forrest, you know why I asked! My pump hasn't been off yet and it probably won't come off as I have more fuel then I can burn as it is, I couldn't imagine another 200cc's or so! :confused: My 10 plate and 191's took me to the top at Piers' Dyno Day this year, although I did use a little bit of H2O/Meth 692. 5/13?? needless to say I'm happy! :eek:
CurtisvilleCummins said:
my pump guy in sandy lake pa. got me 820cc out of a 215hp pump
I'd bet a 215 pump would do that much fuel... ... with 14mm P&B's. With 12's it more like 550-600, 13's... . 650-700.
No one checks a pump flow rate with the injectors they are running, not even me!
Jim
