Anyone know how you test this???
What rearend in 04?
Removal of front Breaks on 2004
This is a waste gate actuator solenoid off a 2005 5. 9 turbo. Does anyone know how you can test it to know if it is good? Can I just apply 12v to it or is there a certain resistance it should read? There is a picture at the bottom.
The label on the solenoid says "12VDC" You could also check it with a volt-ohm meter. Look for some resistance. If none thae I would assume it is bad.
Yeah, I seen the 12VDC on the label, just alittle hesitant to apply 12 volts. Do you know what it is suppost to do? Move in and out or... ... ... ?
It does not actuate the waste gate... ... ... ... It bypasses the boost signal (internal passage)that goes to the wastegate actuator. The grey with pink wire is a 10 amp fused ckt... ... ..... You should be fine applying 12 v to it. It is computor controlled on the ground side.
