auto. tran.
PE-Comp vs. DD Ultimate Fueling Module
DTT Converter & Valve Body Questions????
98/24v 73,550miles- tran started kicking in and out of overdrive around 45mph. changed oil and filter for tran and had dealer reboot - no help - several days later it has stop doing what it had been doing. I didn't have any problem on a quick acc. only while driving at a normal acc. and around 45 it would attempt to go in and then out and finally in overdrive. Dealer has no idea what the causes is other than to start swapping out parts at my cost. Any body out there who has had the same problem or idea of cause, please let me know.
Chect the TPS. The problem may go away with just hosing it down with contact cleaner and cleaning the connector.
Joe George
Eureka, CA
'95 2500 CC auto 4X4,3. 54,Combo EGT/boost guage,custom switch panel,PacBrake,TST #5,DTT TC/VB,Automatic motorhome steps on both sides,Foldacover hard bed cover,Cummins chrome kit,Black steel grill guard,Front hitch receiver, KDP 160,000-NM-WT Insurance
Originally posted by fog:... . Dealer has no idea what the causes is other than to start swapping out parts at my cost... .
[/B]
Why does that not surprise me? Joe G. is right, sounds like a TPS. Take it off and hose the backside of it down with quick dry electronic cleaner. I bet this will fix you right up and it doesn't cost anything to try. If it doesn't work, try replacing the transmission temp sensor. You can get them at NAPA and avoid the dealer screwing, since it sounds like that's what they were warming up to give you.
Daniel
Yup TPS
2001 QuadCab,SWB,Auto, 4X4,4" Flowmaster Raceing Exhaust, DTT TC & VB, EZ Box, Bosch 275 Injectors, Mag-Hytech transmission pan/Dana 70, K&N, Autometer pyro/boots guages, Eclipse cd player, Boston Pro componet speakers, 2 Solo Baric Subs, 33" BFG AT'S... ... .....
