auto transmission capicity
Torque converter problem?
Fuel Gauge Snubber
How much fluid does the transmission hold i looked in the manual and it does not tell you, i just had it changed when i had all the gauges put on but the guy who did it only put in 4quarts that does not seem to be enough.
2500 2001 loaded except leather all stock 354rear end 4x2
Not positive, but I believe the TC only holds 4 or 5 quarts. Either way, just add a quart at a time, checking your fluid level with the dipstick and you'll get there. Make sure you go for a little drive when you're finished and then check the level again.
2001. 5 2500, QuadCab, 4X4, LB, Auto, 3. 55, SLT+. Mods: Silencer Ring removed, EZ, 275's, turnbuckle on the wastegate, DTT VB&TC, PAC-Brake, 3 Gauge Pillar with Autometer EGT - pre-turbo, Boost and Trans Temp gauges, Rhino Liner.
The method I use is to measure how much I drained out and put that much new stuff in. Always right on the mark.
Joe George
Eureka, CA
'95 2500 CC auto 4X4,3. 54,Combo EGT/boost guage,custom switch panel,PacBrake,TST #5,DTT TC/VB,Automatic motorhome steps on both sides,Foldacover hard bed cover,Cummins chrome kit,Black steel grill guard,Front hitch receiver, KDP 160,000-NM-WT Insurance
I just dropped my pan and changed the filter a few weeks ago. I got about 9 1/2 quarts out of it.
2001 2500; SLT; 4x4; QC; LWB; Auto; 3. 54 LS; 265s; Camper; Tow; Sliding Rear Window; Travel Convenience Group; Cab Clearance Lamps; BedRug; Forest Green; Isspro Pyro, Boost, and Trans Temp Gauges; 27' TT
Just changed mine and got 7 quarts exactly. Measured what I took out, 7 quarts. I think the best way for you would be to just use the dip stick since they already changed your fluid. Remember to do it with the transmission at operateing temps.
Ron
1999, 3500, 6x6, slt, auto, 3. 55 lsd, Qd cab, ISB cummins, Isspro transmission temp, EGT, Boost gauges on A-piler, before and after fuel pressure gauge, DD stage 1, modified banjo bolts, K&N 0880 with prefilter, triple trailing 2001 26RKSS Tahoe 5th wheel, 1999 120hp 1800 bayliner. 20,000 lbs GCW.
