RustyJC said:
What is unsaid here is that the torque converter is also transmitting 0 BHP. Basically, the power coming into the torque converter from the engine (BHPin) is being dissipated as heat at the rate of 1 BHP = 42. 44498 BTU/minute, and the mechanical power coming out of the converter into the transmission (BHPout) is zero. Therefore, the mechanical efficiency of the converter at stall ([BHPout / BHPin] x 100) is 0%. Once the brake is released, mechanical efficiency will increase as turbine speed approaches pump speed, but until lockup is achieved, torque converter mechanical efficiency will be lower than the mechanical efficiency of an engaged clutch.
Rusty
Not true, you keep talking about the efficiency of a clutch, but the clutch is only one aspect of the power distribution equation.
quote ''but until lockup is achieved, torque converter mechanical efficiency will be lower than the mechanical efficiency of an engaged clutch. ''
How so? Once the converter is locked up, its a moot point, yet when in multiplication mode, it is by far superior that a slipping clutch, or better, when the manual transmission must shift 1 to 2 times to match the variable output of the TC. Yes, some heat is displaced, but again, so what? A manual clutch doesn't get hot? Automatics and manuals absorb almost an equal amount of parasitic power (and the auto wins this one when locked up due to a more efficient axial power flow route)
And how many BTU's are displaced on each gear change required for the manual (ie consumption of fuel)? Energy required for Increasing and decreasing the mass of the flywheel is free? And how efficient in operating the engine at various rpms? We all know that internal combustion motors have a small window where the power generated vs. the least amount of fuel consumed is very small. Wouldn't it make more sense to operate the engine at maximum volumetric efficiency, and allow the TC to adjust the torque output required? Again, we don't drive our trucks in a static state (flat ground, one speed continuously). We have stop signs, hills, variable loads and speeds. No matter how much you argue, the TC and auto is better suited than the inferior operation of the stick.
I'm curious, and don't take this as a slight and respond that I have ATTITUDE, but how much dyno time (engine and transmission), how many hands-on tests, how many converters, how much research have you done on this actual matter? I get the feeling that you are quoting text book rule vs. actual hands on research.
