Axle fluid capacities
exhaust manifold crack survey
New truck – Cancel Extended Warranty?
Can someone tell me the gear oil capacities for my 2001 2500 4X4 front and rear axles?
2001. 5 2500 4X4, Auto, Quad cab,white.
It took me almost 3 gallons for front and rear on my 96 with the dana 80 rear. It should be above 2 gallons but less than 3 for the pair.
1996 2500, 4x4, 5 speed, pscotty air, 15. 641 second 1/4 mile @87. 34 mph STOCK parts
-- email address removed -- Great Lakes TDR
PURDUE STUDENT
GO BOILERS
Wow. That seems like a lot. Thats 12 quarts of gear oil. The Dana 60 and Dana 70 on my 1968 M725 only took 3 quarts per axle. Am I missing something?
My Dana 70 rear diff. took 5qts. of Amsoil 75-90 with the Mag-Hytec cover. Don't know yet about the front... . I'm waiting for Roy to PLEASE start production for a front cover. Truck has 6K miles. I think the stock cover will not require 5 qts. , but I'm not positive.
White 2001. 5 2500 ST, SWB, 4X4,QC, AUTO, 4. 10's, LSD, 285/75/16 On Weld Outbacks, PIAA 510's, Line-x, Tinted glass, Redline 85+, Blow-by-bye, RE-0880 & 25-0880,muffler fell off,level truck with 2" tuff country kit, Bilsteins at the corners, Di Pricol egt and boost, Mag-hytec "original flavor" transmission pan and Dana 70 diff. cover, Westin Step Bars,DTT TC/VB,yeee-ha,EZ, Custom Plate 24V-DSL
Just did my Dana 80 on a 4X4, 5 quarts, and I think the front is just over 3 quarts. I would have 9 quarts on hand to be safe.
Shelby
2001. 5 2500 QC LB 4WD, ETH (Built 09-10-00), DEE, 3. 54 gears, Laramie SLT, Camper Special, Trailer Tow, Travel Convenience Group, Power Driver Seat, Alarm System, Remote Keyless Entry, Fog Lamps, Cab Clearance Lamps, HD Transfer Case, Bright White with a Gray Interior. Built 09-15-00, took delivery on 10-06-00, 12310 miles as of 05-01-01. Custom aluminum work body / flat bed. Coming soon: E-Brake and gauges.
I just did my rear axle Dana 70 with Amsoil 75-140 and with the stock cover took 4 3/4 quarts. Used permatex ultra gray and no no leaks.
THE ROCK/2001,4X4,3. 54 GEARS,QC,SB,AT,SPORT,Cab Lights,CAMPER PACKAGE,TRAILER PACKAGE,WHITE,MOPAR MOLDED SPLASH GUARDS,STEELHORSE NERF BARS,BEDRUG LINER,CAB HIGH CAP,Full Mopar Body Side Moldings.
I just filled my Dana 80 and it took 7. 5 quarts. My fluid level is above the minimum fill line, but well below the max fill line.
1999 Dodge Ram 3500 Quad Cab 2wd; 5 spd; 4:10 LSD rear; Mag-Hytec differential cover; US Gear EGT and Boost gauges. Stewart Warner Fuel Pressure Gauge with dual senders, Westach Oil Temp Gauge for differential. Rancho 9000's on order, PowerEdge EZ Box, Amsoil foam air filter and synthetics in the motor and differential. Cummins Power, don't leave home without it
[This message has been edited by John Berger (edited 05-16-2001). ]
John,
What is the min and the max fill lines for Dana 80 axle? Does it hurt if you overfill?
I usually try to fill my pumpkin with the rear end on an incline.
Charles
2000 QC 2500 4x4 LWB ETC/DEE, Anti-Spin, 3. 54, Trailer Tow, Camper Special, DD1's, PS boost module, PS high idle kit, PS steel idler pulley, Autometer boost and EGT gauges, Westin nerf bars, Rhino Liner
My Toy
1969 Toyota Land Cruiser FJ40
350 TBI, Turbo 400, ARB lockers front/rear, 4 wheel power disk brakes, 4. 88 ring/pinion, 3 speed transfer case, full roll cage, Warn 8274, MRT 36 bolt beadlocks with Super Swamper Boggers (16x35x15), Saginaw Power steering, custom bumpers/fenders/nerf bars/skid plate, GM tilt steering column, 6 point roll cage, RCI racing seats with 5 point harness. Loves to be pulled behind the Dodge and pass the powerjokes going up hills.
Charles
On the dipstick that comes with the Mag-Hytec cover there are two lines, probably about . 50 to . 75 inches apart. The bottom line is the minimum fill line and corresponds with the bottom of the axle tube. The top line is the max fill line and is probably the bottom of the axle shaft itself. The instructions that come with the cover instruct you to fill the differential to a level that falls between these two lines, with the minimum being the bottom line. If any of you have a Mag-Hytec and the fluid does not register above that bottom line, I would add it until you get to that line, assuming your truck is level.
I just filled it `till it started running out the fill hole (stock cover level concrete floor). I also spilled some too, and didnt get the bottles completly empty.
[This message has been edited by Jff24Gordn (edited 05-17-2001). ]
Just finished the axles. The rear Dana 70, with limited slip, took 3 quarts of Mobile one and 4 onces of limited slip lube. That filled it to the plug hole on level ground. The front Dana 60 took 3 3/4 quarts to fill to overflowing. I wonder if the TRAC LOC unit, due to its size, reduces the amount of space in the third member and gear oil the stock cover will hold? I have heard from 4 quarts to 7 quarts to fill a Dana 70 from TDR members replying.
Also, I cured the front axle gear oil leaking from the vent hose. I put an axle vent tube from a 1981 CJ in the upper part of the cover. Drilled a hole in the cover and brazed the fitting in. I then rerouted the vent hose to the driver side of the vehicle. I used an 1/8" pipe plug to plug the original hose fitting hole on the axle housing. This should stop the front axle from pucking gear oil from the vent hose. I did a survey and most TDR members said they had the same problem.
