Back up light picts
Pics of Westach FP sending unit install
What width are stock rims with 265/75/16's?
Relays in series
Originally posted by John
I went the full automatic route for activation. I have two relays that control backup light activation (in series)... the backup lights will only illuminate if in reverse and the parking (or parking/headlights) are on. :cool::cool: As I already had a 10 ga. wire to the back of my Ram for another accessory (interior light in my canopy :D ), and the backup light circuit was close at hand the wiring was simplified... somewhat.
Hey John,
Could you please give more detail
as to how to go about hooking up the relays as you did.
I would love to do that, but I am a little
Dumb when it comes to relays and wiring.
Thanks,
Robbie
Here's what I found at Advance Auto Parts
These lights (I don't recall the manufacturer) are made to fit the factory
trailer hitch, well made, VERY bright and
easy to install. Here are some pics:
Rectangular
backup lights
detail shot
Wish I could find the receipt. . next time I'm at Advance I'll note the brand and
price and post it here.
-Chris
*DING DING we have a Winnah!!
Yes Bill, they're Pilot Navigators. I was just
about to edit my post to show that. Today I went
by the auto parts store where I got them and made
a note of the brand but you beat me to it! :D
-Chris
I have a pair of aircraft landing lights under the rear bumper.
Theyre good for backing up in a dark spot, and when someone behind you decides to beam you.
I could see their face at 100' in my rearview at night!!
Guess they have some entertainment value too come to think of it. :-laf
Eric
Haven't really looked at them real close, may try to install them tomorrow. Any troubles Chris? Where did you splice them in?
I tapped the power wire for the backup light bulb
on the passenger side. The wire is purple and may
have a black stripe. It's the only purple wire
going thru a harness up to the area of the tail
light assembly. Also, you will have to find a
place to attach the ground wire. I used one of the
screws that holds the black plastic license plate
bezel onto the truck. One of these days I'm
going to put a switch in the cab, maybe on the
steering column or the shifter boot plastic
surround, so I can turn them on when I need to
hitch up a trailer at night. Shouldn't be too
difficult, just have to tap into the wire that
is at the transmission backup light switch.
In case these things are made with cheap chinese
pot metal, I used white lithium grease on all the
screws/bolts/nuts to prevent rust. I'm sure the
Indiana DOT uses lots of salt in the winter so
you might do the same! :D
-Chris
Nice job, Ted. I have very similar utility lights mounted in the same fashion, work great !
I was talking with fellow member EShaw the other night and looking over his rig. He built a beautiful housing for a single Hella work lamp that he attached directly under his hitch receiver, maybe we can get him to post a pic. I can tell ya, it's a real nice, clean install :cool: .
Scott W.
