Axekicker
Very common , You do NOT need to replace ECM, I recovered many from this same problem, It requires someone that knows the work a round's of WItech.
Current problem: Thursday 9-JAN-2020: Volt meter started running high (over 15 volts) recently. The truck was starting to get 'slow' turning-over in the mornings so I knew the battery's were being drained (or cooked). I took the truck back to the shop that rebuilt my motor last year and they said the passenger battery was 'cooked' but drivers was OK (these are new Costco/Interstate 1000CCA batteries). When the motor was rebuilt Nov. 2018, the shop installed ALL NEW BATTERY CABLES & ENDS so that takes them out of the equation. They sent the alternator out for testing and said it checked out OK. They checked the temp-sensor under the drivers battery and said it was OK. It's their 'best-guess'... the ECM is the 'cause' over the over-charge/over-voltage condition and they're telling me I need a new ECM. I'd like to have someone local, perform a 'diagnostic' on the ECM rather than send it all the way across the country to some unknown shop just to hear them say 'oh...yeah! It's shot and we'll send you a new one for $1,000.00+'
Recommendations? Should I have the shop pull the ECM and split the case and do a 'visual' for PC-board damage? (I'm a ham radio guy and regularly split radio cases looking for just that kind of damage to PC boards). IF no visual or 'olfactory' (can you smell the problem?) damage is observed or 'smelled'....then what? I'm not a fan of throwing parts at a problem as a substitute for real 'diagnostics'. I'm not convinced the ECM is the problem here. I'm thinking there's an issue that crops up 'under-load' which static testing won't find. How many times do they bench-test an alternator and pronounce it as "OK" and put it back in the vehicle only to find later that it malfunctions when it gets hot...under real-world loading/driving condtions?
TCDiesel: How can I find a local tech who knows how to do a WItech work-around?
Your thoughts guys?
