Banks turbo housing
High Idle Adj--Best way to turn that Screw?
Need Dave Fritz website
Is the Banks turbo housing with the "big head" actuator a good unit? I'm sending back all the electronics and am wondering if I should send the housing back as well. I plan on buying a Power Edge, either the EZ or the new Comp model. I have 4" open exhaust, the Banks High Ram, 275's (I plan on going to DDII's) and I'm about to order the Psycotty airbox.
Thanks all for your help #ad
2001 Quad Cab Dually, ETH, SLT Plus, 275 injectors, Banks Power Pack.
Powder Extreme, first put reliable gauges, Pyro pre-turbo and boost. Then try the Edge EZ. With your 275 injectors, I think you will be very happy. I had just the EZ and stock injectors and was very happy for a while, then the mad bomber in me took over #ad
. I don't think you NEED to go to a larger turbo housing with the HX35 unless high egt's are a concern, and they should not be with that combo and a 4" exhaust. If you want a larger turbo housing, the HX40 is great on the ETH. Edge is no longer recommending the PE for the ETH, I received this info from Brett at Edge when I was going to piggyback my EZ with a PE. It's apparently only good for another 25 HP or so gain, while putting undue stress on that VP44. Hope this helps your decision. Forgot to add, the "scotty air system" is way cool, literally.
Scott W.
White 2001. 5 3500 ETH/DEE 4X4 Quad cab SLT,tow package and camper prep,Husky liners front and rear,DiPricol pyro,boost and oil temp gauges,Edge EZ,Psychotty air,Bully Dog stage III injectors,ATS 3 piece manifold,HX40 turbo,4" BD exhaust,4" BD E-brake,McLeod clutch,Mallory 4150 lift pump,Mag-Hytec rear,Mopar tonneau,Lund bug shield,PM tractor utility back up lights,Penda bed mat and blow by bottle is bye bye !!! I love the smell of diesel in the morning, it reminds me of... . VICTORY !!!
<A HREF="http://albums.photopoint.com/j/AlbumIndex?u=1231655&a=9089608" TARGET=_blank><font color=red>My Truck</font></A>
<A HREF="http://albums.photopoint.com/j/AlbumIndex?u=1231655&a=9089604" TARGET=_blank><font color=red>THE SAINTS</font></A>
[This message has been edited by Bigsaint (edited 03-04-2001). ]
If you're going to put in DD II's -AND- a PE box,then yes,keep the housing for EGT's. If running just injectors or just a box,then no.
-Mike
Thanks guys, I am definetly going to use a housing for lower EGT's. I was wondering if there is a better unit than the Banks, but sounds like they are pretty much all the same. Gotta go with the injectors and box and all, life doesn't begin till 400hp does it? #ad
2001 Quad Cab Dually, ETH, SLT Plus, Isspro Pyro & 50lb Boost, 275 injectors, Banks Power Pack.
