COMP461 said:SPEED COST HOW FAST YOU WANT US TO GO.
I am going to run a 7 second pass , and to do that it takes light weight parts , and roller cams , High ratio rockers systems , and the ability to buzz the motor up to 6500 RPM's + and make power there. The head we ported was one of many we have been on the flow bench with; it was big, but in no way extreme. I don't post pictures of every thing, but try to give a general ideal of the direction needed to go in to make the power need to achieve the goals. I really believe that when it’s over I can run in the mid seven second ranges. This requires RPM, RPM and RPM, to achieve that you need the one thing that a Cummins lacks Air Flow
I have taken a head way farther then the head you saw, but that is not something the public will see. The quest for Air flow is most of the battle in getting these motors to run
COMP461 said:this is a drag racing piston, and not a pulling pistons ,
Sled Puller said:Definition: "Drag Racing Piston"- COMPS design, light duty, cheap, low power. For applications well under 1000 HP.
I'm thionking a pulling psiton will break 200 MPH in the 1/4 before yers does, COMPy.
COMP461 said:I am confident with stock rods the stock Cummins piston will hold up just fine, no need for a Aires piston, a waste of money.
Then you might get an ideal of what I am trying to accomplish.
sbentz said:Well, as you will see below, the failure had no connection to oil. Matter of fact, it probably kept us from seizing the piston. And by the way, I don't know what oil you like, but Lucas has done pretty darn well for us.
Hohn said:I know- but since you're one of the best guys here, I thought you needed a little sponsor-ribbing
Might want to check the windshiled wipers on the car, too![]()
Justin
RacinDuallie said:Definition:
Arias in 'Componics' = Aires
Sled Puller said:![]()
I guess I have been reading arrogant Texan long enough, even before COMP, that I understand it!!LOL Hence "maJic".
Now, where was I? Oh yes, COMP, let me know when you catch up to anybody.
You had ONE good downhill run, and haven't backed it up since. Old news.
COMP461 said:Have had several good runs, all 1/8 mile runs in the low 5 second range ,
Sled Puller said:So 10 second 1/4 mile, cool, you can almost catch TS Performance!!
ROTFLMAO!!!!!!!
