Best place to buy Mickey Thompson/Alcoa wheels?
Gauges install questions
MagView Cover
Hopefully this does not throw a big wrench into what you are trying to do but... ...
If you are going to spend for the 16" rims why not spend a little more and get the 19. 5's?
Getting a G/H rated tire on a 19. 5" rim that will last a lot longer might help you in the long run.
Just a thought...
Paul,
Just did this purchase. Desert Rat Offroad for $168/rim not including center cap. Discount Tire initial bid of $205, but of course they would have matched DRO if I asked. National Tire is good too, but adding the $75 for shipping to NM made it a wash buying local and paying tax.
If they have to order lugnuts make sure they check your size on your truck. My 98. 5 showed a 14. 5mm X 1. 5mm or something like that on the computer and they were the wrong size. Ended up with 9/16" and had to purchase from Discount tire and then get reimbursed.
Very nice looking rims for the money. Had been set on the Weld F1 Renegade, but when I went to order them, the polished version was already discontinued. They are only offered in chrome now for $80 more per rim. That put them in the $330 per rim range... ouch. :eek:
ic
I got mine from Desert Rat and had no problems with the shipping or the lugs. The "Challengers" are expensive ($165/ea) but they sure look good and will handle the GVWR of the 2500. They were drop shipped in abour 4 days from time of the order. Good luck. :rolleyes:
