Removed the check ball from the cooler line?
I put 65,000 miles on my stock trans with no problems. Ever since the aftermarket worked trans was installed I have temp issues. Is this common?
Should we remove the check ball?
The check valve is untouched, stock. Should I check it? Keep in mind there were no trans failures on this truck so I don't think debris is a issue.
What is it about a TC design that might make it generate excessive heat? On the other hand, what might be the issue with my trans cooling system that causes it to not cool enough?
How do you remove the check ball? Does it fall out when you unscrew the fitting or is there more to this?
what is the point of removing the check ball? why is it there?
