I have a 2002 Dodge with a BD Exhaust Brake and Guages. I maybe moving to the midwest where it is much colder than where I live now. I have read in the owner's manual that it's possible to have it start on 3 cylinders with a fast idle to help it warm up quicker. I think it would have to have the ECM reflashed?
At any rate I notice that when I turn on my exhaust brake on a cold morning
that the EGT is around 400 degrees. If I turn off the exhaust brake and use the accelerator to increase idle speed... I have to run approximately 1600 RPM to bring the temp up to the 400 degree mark that the exhaust brake does at idle.
It is my understanding that low idle temps can create problems with incomplete combusion and the "washing down of the cylinders" with the unburned diesel fuel?
Given the above scenerio, is it suitable to just use the exhaust brake to warm the engine and prevent the problems with low idle temps? Or should I invest in having the ECM reflashed to run on 3 cylinders on very cold starts?
Is the EGT the only measure needed to insure proper combustion or is it more involved... perhaps the temperature of the coolant?
Thanks ahead of time for your input.
