Hey Gary,,
Can I have a PM also?
I think that vapor lock situation has made plenty of VP44's be replaced when they didn't need to. What I have found out about the vapor lock, is, All you need is some more RPM. The starter only turns the truck over at 100-200RPM, and you really need 500RPM+ to get the truck fired without cracking the lines...
On my truck, If it shuts off from vapor lock, I just let the clutch back out in gear to get the RPM up again (above 500RPM) sometimes it has taken 1,500RPM to get it fired back off.
What I think what happens, is the pump aeretes (air in fuel) the fuel and it gets air in the lines,, but it's just a little bit of air.
AUto transmission guys are stuck crackin' the lines, but the manulas can get some speed up and a good clutch workout.
I didn't think it was possible to suck the fuel lines dry since,, once the truck is running, the fuel system is a "closed loop".
Merrick
