Those B1's are FAR from indestructible.
A 24 valver with 350 HP bought it and drove it for 1500 miles before going to twins. He didn't ever pushed it over 45 psi of boost. The turbo felt tight and I knew it hadn't been abused, so I thought I would try it out. I have been wanting to try one since I read all the raving reports.
I installed it, lubed it, let it idle for 5 minutes. Then I drove home nice and easy. The next day I drove 3 hours to the race track. Again, taking it easy all the way. I had changed my oil less than two days before installing the turbo, so dirty oil isn't a problem either.
I'll have to admit, going from the H2E I've been running, I really liked the spool up. The turbo felt nice around town.
But then I decided to make a few passes down the 1/4 mile. I made one pass taking off very slowly and ran 14. 0 @ 99 mph.
The next pass I decided to turn it up a bit. I launched fairly hard and reached for the nitrous button. As soon as I touched the nitrous button in 2nd gear, the turbo exploded.
My SPA digital gauges recorded a peak boost of 62 psi.
The turbo blew completely apart. One of the wheels blew a hole through my hood and left about 5 dents in it. Both intercooler boots on the passenger side of the engine have holes in them from the flying debris.
I pulled the intercooler off and found pieces in there as well.
I pulled the motor and found two pieces in the oil pan!
It seems that two pieces found their way down the oil drain straight into the pan.
So I have a ruined hood and two ruined intercooler boots.
Then throw in the fact that I get NO warranty.
I don't believe this is a case of an over-torqued nut. Nothing is salvagable from this turbo. Both wheels are gone! The compressor housing has holes through it from the explosion. Even the turbine housing has a hole in it from flying parts.
J. R. , My pump has put out 1050 ccs on the pump stand, but I had it turned down slightly while the B1 was on.
-Chris
