I don't think it was leaking after all. There are no holes in it. I just couldn't imagine at the time that the turbo was failing. It failed as a result of the bearing locking up, pretty sure anyway. I am taking it off right now.
Jeff, its not just phat shafts the failures are not brand specific since they are using the same borg warner parts then any of the above you mention are just as likely to fail.
It's kind of like FASS issue you hear alot of issues but they also probably have the most aftermarket systems out there. . Just like II probably has the most aftermarket turbo's out there at this point (relatively speaking).
The oil pump does pump the oil through the filters before it goes through the motor and not the other way around right??? .
Got it off and as you may already have guessed the exhaust side was in no better condition. In fact all the blade tips were bent and one tip had broken off. Quite a bit of the blades on both sides have been ground away and both are very sloppy.
I called Brady and have since overnighted it to him. Wished I had gotten a pic of it but didn't remeber until I had it wrapped up and I had no time to spare in getting it to UPS.
I cut open my full flow amsoil filter and found some very small pieces of metal in the bottom. Oil also has a metalic look to it so I guess more metal got injected than I had hoped. I am going to drain the oil and drop the pan to clean eveything out as much as possible before I try to fire it back up.
The oil pump does pump the oil through the filters before it goes through the motor and not the other way around right??? If that is true maybe I won't have to many bits of metal flowing throughout the motor.
I'm sure they have, but I haven't heard of the Super B's doing this.
I agree, I think its a fluke as well. Seems like you always hear the bad more than the good...
Take my dodgezilla for instance. Way overfueled, and everyone says they are prone to explosion. Ive ran it at 50psi, gotten it waaay hot, and its still kickin.
Is this the "phat shaft?" Is it fatter than other turbo shafts? That may be ironically why it fails. See this engineering paper on turbo design.
