Gee, I installed mine right after changing the oil in my truck and installed the ats manifold and now I am burning oil... truck is smoking its tail off.
i've been hearing this fluttering noise coming from i think is my turbo. it happens when the boost starts to build and continues till i let off the pedal. i can really hear it in the exhaust noise when i drive by a wall or close building. any of you that have had a sps 62 blow ever hear any sounds like what i'm describing? i've been thinking about putting the stocker back on and sending mine back to be checked out and updated to spool faster with the G56. there is no end play or side to side on the turbo... . james
wow..... I wouldn't pay them a dime on this one. If they don't warranty it then tell them to keep it and take your money and business elsewhere. HTT sounds better and better... ... . Let us know what happens. I had a kwikspool B1 on my 03... bought it from Piers. Drove it literally 40 highway miles..... It blew and they denied warranty... . needless to say they didn't get my business again... ... and I know some people swear by them but that was my experience.
How many of these aftermarket companies test for those critical frequencies, to determine what RPM's are to be avoided, and then go back and redesign them to not fail within their advertised specs?
Part of the problem is surging. The other part is critical vibrations, which the article I posted on previos page explains a little bit.
What it means is that the length and thickness of the shaft, and the size and weight of the rotors, has a lot to do with what rpm they resonate (badly vibrate) at. Those are forbidden RPM.
Just testing at maximum boost is not enough, if you have one of those bad resonances at an intermediate RPM/pressure. That's how they can hold up fine in competition, but fail on street driving.
By the way, jet engines operate above the critical speed, and they are required to accelerate quickly above that speed (from idle), but this is not possible with a street driven turbo. They have to operate below critical speed, or they blow up in normal driving.
First off, if you can't afford your truck to be down, don't bomb it.
Look at this from the vendor's point of view. It plays out like this. Turbo comes back with fried bearings and the wastegate adjustment is as high as it can go. The customer admits he has a boost leak until he realizes this will overspeed the turbo and damage it then he changes his story. I see it as he had a boost leak and rather than fix it he just tightened up the screws to get the boost back. Turbo got fried. Simple.
I wonder how many of the others that had failures would honestly admit that they blew a boot off a time or two.
