Engine/Transmission (1994 - 1998) Boost Bolt
2nd Gen Non-Engine/Transmission Antifreeze Smell - Heater Core??????
Engine/Transmission (1994 - 1998) 2nd gear lockup rh?
Will the boost bolt for the second generation motors work on a 1998 12valve? We need to install a boost gauge and really don't want to drill and tap if possible.
THANKS... .
The head should already be tapped for a gauge. If you look on the head close to the intake manifold and if looking from the side between the injector lines, there will be a 1/8 npt plug.
