boost elbow below turbo
Cam Plate
New Cummins Owner on the Block...
i was told i can plug this hole below the turbo housing and not put the brass elbow in when i install the torque plate..... Any one plug the hole and is there any long term consequences if i do it? should i stick the elbow in
[This message has been edited by RedNut (edited 09-23-2000). ]
Why not install the fittings they sent with cam plate. More boost only works with more fuel. If you only have enough fuel for 28-30 pounds of boost 45 lbs won't do anything more for you but probably shorten engine life.
1996-3500 tst #5 plate, K&N air filter,Primeloc fuel filter kit,4" exhaust,bigger injectors,b&m trans pan,Amsoil all around,temp gauges out the wazzo,much trans work,double tow 33' 5th wheel and 12' trailer w/motorcycle(Honda Valkyarie Interstate)Also have 1999-2500-stock. Transfer-flow 98 gal bed tank on order.
I ran an experiment & disconnected the line to the wastegate, which has the same affect as plugging that hole. Here @ 5k' elevation, there was no difference, 32psi max boost. Down @ near sea level, 38psi.
Boy was I around that Accord lots faster. Seat of the pants said there was a difference too. #ad
I wondered why the rear end was more squirrely than before. #ad
Needless to say, I enjoyed the 5th gear passing, big time & less smoke. #ad
Money Sink - 96, 5 speed, Injectors, TST #11 set @ 340hp.
4" CAT back & CATless, 4" chrome turn down straight out back.
ISSPRO Pillar, Delvac 1 & Amsiol, K&N, Monicas silencer ring removed, Exhaust brake, Mag-Hytec, 3:54, 235s.
HX35s days are numbered, HX40-16 is here.
Un-Bombed = Boring
Forrest you got the fuel and exhaust flow to handle the extra boost. You should evan be more impressed with the turbo housing change also.
