Boost gauge fitting location?
WHEW HOO, I've got my OH TWO!!! (pics)
2001 Govenor Spring Kit any diff. early yrs?
Just about ready to install my VDO gauges. My previous 12v had a convenient 1/8" plug to remove and install the fitting. On my new 24v I see two larger plugs beside what I assume is the intake air temp sensor way in the back behind the fuel filter. Is either of these a suitable place to install the boost line? If so, are these two plugs NPT thread sizes? FWIW, I like to tap off of the cigar lighter for my 12v power and use a 1 amp fuse for the gauges.
Take a look a this page, the plug to the left of number 8 is the one you want.
You will need a 1/2 inch drive extension and a ratchet. If your truck is new, you should be able to take the plug out without any problem. If your truck is like mine ( 40,000+ miles ), you might need to warm the engine up before trying to remove the plug. The plug is 3/4 inch NPT, you will need to find a bushing to get it done to the size you need. I had to use a 3/4 inch NPT to 5/8 inch NPT bushing, then a 5/8 inch NPT to 1/8 inch NPT bushing.
Hope this helps, you can find all the information on my How-To page.
I have installed 2 boost gauges this month, and here is how I did it.
Remove air intake horn (4 bolts) and loosen band claps on upper rubber boot and it comes right off--and you can reuse the gaskets. Drill & tap rear of air horn (back side is nice and flat and hides fitting) for 1/8" pipe, then install fitting and reinstall air horn.
Much easier than getting to that 1/2" pipe plug in manifold and pressure readings will be more consistant--no pulsing.
Just my . 02 cents
Max
I don't get any pulsing from the "test port". I have heard that some people have had that problem. Do you know what type of gauge they are using?
You can tap air horn , remove clanp on air intake hose cover with plastic bag and tape , stuff big wad of plastic bags up in air horn past place to tap , drill hole tap , remove bags , remove tape and plastic from hose , replace hose and clamp ,done . I used the top at the place it widens and is flat . about eight inches from the clamp area. Ron in Louisville KY:rolleyes: :rolleyes: :rolleyes: :D P. S forgot let the chips fallout wipe inside of horn then remove wad of plastic gravity helps keep things from getting in the eng but a little wipe is all it takes to get it all chip free.
