Bosch 370 injectors
Valve adjustment
Rubber bushing in my Getrag?
I am only aware of 1 person that WAS making EDM injectors for 12V engines. Don M has pretty much given up on them as there has been no demand for them. This is from him as of last week.
He will still make them but I think they are going to be more expensive now.
Carl
Russell- go to www.f1diesel.com for info about EDMs. I got mine from Rip Rook. Might check your timing and KSB for the smoking blues. THe MACH 1s I had added a LOT of power- I'd say 35-40hp over stock (no dyno, just looked at the jumping boost gauge, jumping pyro, and smoke, which was a little less than before- but still plenty), and I have the hotter stock injectors to start. I'd hate to see what PODs would do to my clutch.
Pastor- I think you need to clean your glasses. I SAID 375mm, not cc. It says on the data tag of Mom's pickup (my case has been replaced- no tag) that it makes 160hp @ xxtiming, 74mm/ stroke. May not be 800hp for 5x as much (but that would depend on injectors, turbo, exhaust, etc), but more than a lot, dare I say most, of us flow.
-DP
"... ... ... ... Pastor- I think you need to clean your glasses. I SAID 375mm, not cc... ... . "
Ahhhh rats... sorry. I got smoke in my one good eye and can't see outta the other one... sorry for the misquote/understanding.
Mind you, the effective stroke is what developes the cc/mil. . so maybe I can hide behind that a tad... . ;):D
Anyone thought about altering the "effective stroke" and methods/results of that... . psssttt..... ;)
Ok, I gotta go to the eye guy next I suppose... .
Pastor Bob... .
"Good info, I am tired of having people think my truck is blown up when it is cold out, or it isn't warmed up. I have been in contemplation over this for quite some time. I would like to know more about the EDM's, where can I find it? Or should I just have the switch-a-roo with the 370's and be happy? If I did not have to drive my truck every day, I would not mind the bluish haze when cold too much. "
Thanks,
Russell
I would go to Buddha Power and mail them about some injectors for your truck they should be able to help.
