2nd Gen Non-Engine/Transmission Brake Pedal Adjustment
Engine/Transmission (1998.5 - 2002) Flashing lights
Last night my stop light switch would not make full contact with the medal brake lever. Thus leaving the brake lights engaged, after further inspection it seems that over the years my brake pedal has some slack in it. Do you all know if there is adjustment in the brake pedal or would I need to find a new brake pedal assembly (I have taken the bracket off and in one of the two bolt holes there is some adjustment available but that did not relieve the problem.
Thank you all for the help
You need to adjust the brake light switch. How to do it is in the service manual. If you don't have the manual you can get one on CD from Geno's Garage for $30.
