Bucket seats and console.
Minimize haze at idle.
1st Gen rear seat belts
There is fab work unless you want your floor boards to crack. A bucket seat cab has extra reinforcements under the cab to support them. The mounting holes for the bench seat are not the mounting points for the buckets. The bucket outside mounting holes are about 1" farther into the cab. Mounting the bucket into the bench seat mounting holes on the driver side will have the door inner panel touching the seat when closed. The seat isn't centered to the wheel. If you look at the right side of the cab in that pic there is also some brackets used in the right side tilt system.
Here is a pic of the bottom side of a bucket seat cab.
I found all the finer points of this subject when I replaced the cab on my truck a couple of years ago. Mine was a bucket seat truck from the factory.
As long as you reinforce the bottom side of cab Yes they will Bolt in .you will have to do some drilling And change the inside of the seat belt to Bucket style .
