First, I didn't use any expanding foam-- I just duct taped it. It's actually quite easy to bridge that gap, and it worked MUCH better than I expected it to. It doesn't leak at all, as far as I can tell.
The elliptical PowerCore filters are what I originally had in mind when I called Donaldson up looking for a possible BHAF improvement. After talking to their engineer for over an hour, he convinced me this was a better setup, because:
1) Air gets a relatively straight shot though the filter.
2) The elliptical filters are two-stage, and MUCH more restrictive. They are designed for mining and agriculture, not on-road. Think industrial here-- not performance.
3) the velocity stack feature of this filter enhanced flow potential as installed.
4) It should fit because a traditional BHAF fits.
Nick, I think that with the setup duct taped, it may in fact fit on a 3rd gen! I wish i had a 3rd gen to test it on or see if it worked.
I recently exchanged emails with Donaldson. They told me that they COULD do a 4" version, but it would NOT flow as well as the 6" version I am testing. The element moves so much air that anything less than 6" reduces the flow through the filter! Thus, we are now to the point where the OEM ducting is the largest restriction in the intake! Works for me
I also asked them a couple questions, which I am waiting for answers to. First, can i post a point of contact here so people can email Donaldson and get answers straight from the horse's mouth? How can we set it up to be tested on a 3rd gen?
I proposed to them that we try to get more of these out there and tested, ESPECIALLY on 3rd gen trucks. Since the fitment on MY truck is resolved to my satisfaction (I don't mind the tape), and since it could easily be adapted to any 2nd gen (as far as I can tell), I don't think the 2nd gens are a problem. 1st gen trucks aren't much of a market (small numbers), but there's so much space that I think installing one would be doable.
So it's the 3rd gen trucks that really need to have a solution with this filter. The tapered housing greatly helps with space issues.
If I get the go-ahead to post contact info, I'm sure they would like to have a 3rd gen tester!!
Finally, I proposed that my contact join TDR/DTR so that 1) he can best research the market, 2) he can find qualified, experienced testers, and 3) he can answer questions directly.
I won't hear anything back until Monday at the earliest.
Meanwhile, I love taxiing down my street and into my driveway
Justin
EDIT: No word on availability yet, as I think they are hoping to have a one-size-fits-all-CTDs solution before they market the filter. I would be surprised if this filter was a go-ahead before October.
I didn't take any pics of just the element. The element is glued to the tapered part, so it's not replaceable. Like a BHAF, you have to replace the whole thing if you want to change it. Removing the end cap (ring thing that's clamped on) will NOT help fitment in any meaningful way, as it just slides over the element to protect the sides.
