Ground Vehicle Standards
These standards documents (commonly referred to as “J” reports or “J” documents) cover hundreds of interest areas relating to ground vehicle design, manufacturing, testing, and performance.
The word "design" is in there. You can make it look like what ever you want it to look like. As in the case of the Prowler. But that vehicle like all others is designed in accordance with the standards set forth by the SAE. These standards are dictated. That's why the Prowler has fenders on the front wheels and the rear meats don't bulge out past the fenders etc. The placement of the tail-lights to the materials the brake rotors are made of is dictated by the SAE. The size and type of bearings used in the axles is set forth by the SAE. The parts counter man doesn't decide which bearing will go into a newly designed rear axle. An automotive engineer does when he designs the new axle. And he refers to the standards set forth by the SAE or a new standard is created. And a new axle is designed.
When our engineers design a new elevator, it can look like a tin can if that's what the customer wants but, it will be designed in accordance to the standards set forth by the ASME or it will not pass final inspection and will not be licensed for use. The ASME does dictate what the capacity of the elevator will be for it's given purpose and the material it will be made of and the grade of that material and the nuts and bolts used to hold it together. I have the book out in my truck. They are quite expensive and thorough.
I just went back and re-read my post that probably got the threads all crossed up.
"I'd have to design my items to only last so long. The SAE does just that in hopes that people will replace their vehicles in about 80-100k miles with new ones. "
The automotive engineers who are employed by the big three who make up the majority of the SAE membership, have a definate interest in longevity of a wheel bearing. If the automaker (employer) wants a wheel bearing to last a given amount of time (mileage), it can be done and it does happen through design by the engineers. It would be cost prohibitive to design a vehicle to last a million miles. It would also be disasterous financially to design a vehicle to last 25,000 miles as in the Yugo. Either way, the wheel bearing will conform to the standards set forth by the SAE for reasons stated in Amianthus' post.
So I can see where my poor choice of words, likely a result of my *exquisite* choice of beer, has caused a total meltdown of comunication and confusion amongst the masses. My sincere appologies sire.
