obert said:Alot of good points here, and maybe each are right in different views. I dont have experience to say one way or the other on a modified ISB in a Ram, but I can with no uncertainty say that almost evrey QSB engine (they come in 4 or 6 cyl, and use the VP44) does not use a lift pump of any sort. The engine has to crank long enough to pick up electronic loation sensors (Cam & Crank), that the internal charge pump can build up.
The QSB is an ag/ind. version of the ISB, pretty much picture 24v electronics and pump on a 12v engine.
bottom line guys, a VP44 can sart the engine without help
Remember this happens with minimal fuel line restriction, and the RASP may be enough to stop the process unless an electric pusher is involved to get fuel passed the RASP.
Just a little info to feed on.
Thank goodness some other people chimed in on the Don M approach I mentioned it earlier but finally gave up.
