Camper help
Can I change tire sizes?
Running warm, Low power, Bad mileage - Sick Truck!
I just purchased a Lance slide in camper. The problem is that I have a 1 ton 4x4 truck which sits very high in the back. The jacks just touch the ground, is there a way to install extensions on these jacks or lower the truck?
Thanks. Ken
You could also carry blocks around. My Lance reaches on my 2002 4wd, but I'm near the extension limit of the jack. I put blocks down for comfort really.
Same here,
The jacks reach on ours, but the blocks help keep a little more overlap on the jack legs. They also help if the ground is a little soft by spreading out the weight and keeping the jack leg feet clean. The blocks are 1-1/8 plywood 3 layers thick stepping down from 16" to 10" to 5" . The blocks can also be used to drive up on the help level the truck/camper as well.
Greg
Thanks guy's
That was good information. I have a new 06 truck coming, same setup does dodge still lower the rear end?
Again thanks, Ken
Thanks. Ken
Do you have electric jacks? I have Atwoods and they work fine.
Jim
Jacks
That's what I have, in order for me to load or unload I have to use blocks.
Maybe atwoods newer jacks have longer shafts.
Ken
