I have Goodyear Wrangler 305/70r 16's on American Racing 16 x 8 aluminum wheels. Just had them rotated the other day by Tire Discounters here in Cincinnati area. Originally, they only did a static balance where there were weights only on the inside of the wheel where you couldn't see them. There was some wheel induced "hop" in the rear as I could see the bed vibrating up and down at certain speeds. I had them do a dynamic balance where weights are put on both the inside and outside of the wheel. They used a whole lot of weight and it looks terrible. On a six inch section of wheel there are four different weights. Doesn't look right to me and the vibration is worse! They probably damaged the outer rim of the wheel too since I heard them hammering the weights on to the wheels while I waited.
I've heard that there are many different ways to balance tires and wheels such as rubber patches placed inside the tires, rotating the tires on the wheel to "match" the irregularity of the wheel to the tire as close as possible, and different kinds of balancing machines. Hunter has one that simulates a road surface under the wheel to check for balance under load.
Has anyone found a solution for difficult to balance tires and wheels?
'99 2500 4x4 long bed quad cab auto with sport package.
My Toys
My Toys
