$10. 000. 00 fine and some jail time is possible for messing with the cat. I believe the cats construction is different from the automotive configuration as it pertains to restriction and back pressure.
I am running the straight pipe with the kitty on the 05, when getting on it hard at low RPM you can clearly see the black smoke exiting with with out much restriction when using a turndown.
As far as the sound without the muffler it works for me, very little to no drone when empty, slight drone when under hard throttle while towing. There was a member who had his warranty voided due to the cat removal,you need to rethink removing it.
Mac
