Originally posted by Murle
I have a question. I'm thinking on leaving my original ecm in its place and just putting the MAD ecm just close where I can plug it in. Was wondering if anyone knows if the ECM needs to be grounded????
According to the service manual under ECM installation:
Do not apply paint to the back of ECM. Poor ground will result.
(1) Clean ECM mounting points at engine block.
(2) Position ECM to engine block and install 3 mounting bolts. Tighten bolts to 24 N*m (18 ft. lbs).
(3) Check pin connectors in ECM and 50-way connector for corrosion or damage. Repair as necessary.
(4) Cleans pin in 50-way electrical connector with a quick-dry electrical contact cleaner.
(5) Very carefully install 50-way connector to ECM. Tighten connector hex bolt.
(6) Install battery cables.
(7) Turn key to ON position. Without starting engine, slowly press throttle pedal to floor and then slowly release. This step must be done (one time) to ensure accelerator pedal position sensor calibration has been learnd by ECM. If not done, possible DTC's may be set.
(8) Use DRB scan tool to erase any stored companion DTC's from PCM.
end quote.
Yes the ECM does need grounding.
cul,
Casey
