Let's hear it from the horse mouth.
Each year, transmission, HO, SO, has a different software. So it is not that I cover all the ECM's with the same software. It seems that we have a problem in determining the correct SW for the 2001 trucks.
For the '98 trucks there are two different SW's.
Automatic and stick.
For the '99 trucks there are two different SW's.
For the '00 trucks there are two different SW's.
For the '01 trucks there are three different SW's.
Automatic, stick (5 speed ) and HO ( stick 6 speed )
For the '01. 5 trucks there are three different SW's.
For the '02 trucks ther are three different SW's.
Let's assume for a moment that every ECM I get here is the original one out of the truck. Problem solved, because I can determine which SW version that ECM has in it and replace it with the CaTCHER version for THAT version of truck.
The problems we have today are due to the fact that ALL ECM's are spare ones. Which SW does that truck need?
Use the 01. 5 SW version in a 01 truck and the result is:
PROBLEMS.
We're working on it...
The four guys that have problems with the ECM are all 2001's.
The fact is that I wasn't aware ( should've been, my fault, lesson learned ) that there are the 2001's and the 2001. 5's. "Early build" and normal for DC. ( Rear barkes, drum or disc... )
Two of them got the "Normal" SW instead of the "early build".
Bingo!
For the other two I'm not yet certain to what causes their problem. I'll know more once I get these ECM's here.
What do you want, nobody is perfect...
To make things even worse... .
Saturday 07/31 I'll leave for my vacation. So we had to SPEED up things in order to try to solve the problems before the vacation.
I think that gives you the whole picture.
Ciao,
Marco
