rubberneck,
What you've been told is probably what I've said here on TDR several times.
What I know for sure is that I've seen several DC softwares that had a fuelling map which caused that problem in MY truck. I changed the fuel map, the problem was cured.
So I said that on TDR...
No, none of the trucks with that problem has ever had an ECM of mine. ( As far as I know )
No, I'm not certain that the problem YOU have is the same to what "I" have seen. Sure enough every time I hear about that problem how and when it occurs, it sounds da# the same to what I've seen.
I CAN NOT say for SURE but I THINK that "this strange shudder or bucking under load at moderate throttle. It is most pronounced between 18-2300 rpm. The bigger injectors I add, or more fueling box, the worse it gets" is caused by the ECM software.
So the verdict is still out... .
Marco
Marco
