Bob did you get the 2 ECm's I sent to ya'???
According to my tracking you should have em'
Now What??
DM
Now What??
DM
DjFire07 said:Bob, you just took away my Catcher?
Bob Wagner said:Bill's ecm will probably only used as an Italian frisbee :-laf
Rock-N-Rammer said:Now that would be a good use for that!
It's too light to make a good boat anchor![]()
My CaTCHer should be here on Monday, unfortunately I won't be here until Thurs... :{
dieselbomb said:I just installed my new Catcher with my Drag comp. Noticed that under full throttle the truck seems a little flat and if I let of the throttle by 50% the acceleration improves. It seems to happen to slightly different degrees depending on which Comp Level I am running. Could the timing be too far advanced, or too much fuesl? and yes it is the "Speciel" ECM for the Drag Comp. I had a coupe of occasions where the I noticed what felt like some "missing" under full throttle operation, but not every time
BRI7070 said:Quote:
I called Bob and decided to run the original Catcher and get a TST box.
