Engine/Transmission (1998.5 - 2002) caTCHER ecm (Marco's aka MAD)
Engine/Transmission (1994 - 1998) So how much blowby is normal?
2nd Gen Non-Engine/Transmission Hurricane Rita
mileage is low 16's do to not being able to able to get by the fun factor and I am running Mach 2. 4's too.
Its a 7100 lb fun to drive truck.
Headed to the beach and back 7-25 through 7-28 and that will be all towing at sea level.
I will post hand calculated numbers again, computer showed 21 plus on the last 1/2 tank #ad
MAD milage
16's don't sound so bad under the circumstances. I was getting 17's playing with the fun factor after I did my EZ & mach 1. 5 install. When I settled back to "normal" driving I was getting 19-20 with a top of over 25 on one steady 65 mph run.
With mach 2. 4's I can understand why you & your friends are smiling. :D
Sorry if this has been covered. I've read probably 90% of this thread but didn't see an answer to this question.
Does this new ECM have high-idle for when it gets cold? I saw where it was asked a few times, but haven't seen an answer yet.
Thanks,
Chris
c-hawk
Originally posted by Marco back on page 10
jcbrown,
the softwares I use have the cold engine high idle incorporated. What I've not been able yet to confirm is if they need to be enabled by a dealer or not. Worst scenario you'd need to get it enabled by a dealer.
Marco
Jared
Thanks,
Chris
Its there, but the question remains is it enabled or not. Going to see if a nearby dealer will hook up the DRB III tool when I get my ECM and check to see if its enabled or disabled.
I kicked my self in the ass again today for not trying the cc. The only time that I use cc is across state trips.
Tomorrow for sure I promise (again) :(
:rolleyes: looking at the bid history, it was kinda close there at the end:D
3 seconds
Seriously tho, I've been working on the last few that have been up for bid.
TC
