Sense changing to Donaldson oil filter I DONT HAVE THAT PROBLEM anymore.
Paper Donaldson or synthetic?
Last two times I changed oil using Wix filters the ring stayed on. I always clean surface before putting new filter on and caught it then.
Also, why would you crawl under truck to change filter. Loosen a couple of hose clamps on turbo intake and intake comes right off. Filter is right there, easy to change
I always open the first bottle of oil and smudge a little on the seal and then hand tighten 3/4 of a turn. My first job was in a Garage changing oil, and it was taught to me by the very experienced mechanic/owner of the shop. I have never had a seal stick to any engine. I have had to fight many oil filters when someone else had used a filter wrench to tighten them. I do use a filter wrench on my boat filter because I can't get my hands in to hand tighten it, but I do make sure it only turns 3/4 of a turn.I always check, however I never have one stick. I always smear a film of oil on the seal and always install hand tight.
Nick
Nick
