Message Description Correction
110 A failure has been identified in the cluster
CPU, RAM, or EEPROM.
1. Replace the faulty cluster.
900 The CCD data bus is not operational.
1. Check the CCD data bus connections at the cluster.
2. Check the cluster fuses.
3. Check the CCD data bus bias.
4. Check the CCD data bus voltage.
5. Check the CCD data bus terminations.
920 The cluster is not receiving a vehicle speed
message from the PCM.
1. Check the PCM software level and reflash if required.
2. Use a DRBIIIT scan tool to verify that the
vehicle speed message is being sent by the
PCM.
921 The cluster is not receiving a distance pulse
required.
distance pulse message is being sent by the
PCM.
940 The cluster is not receiving an airbag lamp-on
message from the ACM.
ACM.
2. Check the ACM fuse.
950 The cluster is not receiving an ABS lamp-on
message from the CAB.
CAB.
2. Check the CAB fuse.
999 An error has been discovered.
1. Record the failure message.
2. Depress the trip odometer reset button to
continue the Self-Diagnostic Test.
