I Just installed a set of set of Centramatics on my truck. I also put on a set of Cooper Zeon tires as well. I am quite pleased with both so far. 300 miles. No more vibrations at all. My shifter would vibrate a little but now it is steady. I have the factory chrome covered steel wheels. I used the 300308 balancers with the "B"'s on the front with the tube towards the rim and the "A"'s on the back with the tube towards the rotor. I have trouble with mud in my rims quite often as of late and took out a front wheel bearing because I lost a wheel weight last fall (hence the Dynatrac freespin). $214 seems not too bad for a set. I wish they would do a TDR discount. Now I can change my own tires as I don't have a balancer.
Just a little info as when I did a search I came up with very little info.
Does anyone else run Centramatics?
Chuck
Chuck
