OK. I've had a blowby issue since I got the truck.
I've been told it can be any of the following:
1) head gasket
2) turbo seals
3) rings
4) bad injector
5) bad exhaust valve guides
I ran a manometer test (home made variety) and got about 2. 5 times the normal readings. The engine doesn't use oil, but it does have a LOT of blowby. When you stop at a light at night, it looks like someone is pouring oil on the exhaust manifold.
I just got the results of my lastest oil analysis yesterday. I called them today, and asked them some questions and below are their answers based on the analysis.
1) head gasket - none of the tests indicate any kind of leakage unless it is possible for it to leak compression without getting antifreeze in the oil
2) turbo seals - IF the turbo seals are letting pressure get by and into the crankcase, this could fail to show up in the analysis
3) rings - none of the tests indicate abnormal wear at all. Chromium was only 3 ppm, and iron was 55 ppm. The tech said if there were any wear issues (like bad rings), the numbers would have been a lot higher
4) bad injector - this may be an issue, but there is no fuel dilution (< 1% vol)
5) bad exhaust valve guides - again, none of the analysis seem to indicate any abnormal wear of the metal components in the engine.
The only abnormal things were high silicon and a slightly higher than normal viscosity. The high silicon may be from my sampling, or from antifoam agents, as it was kind windy that day, and some dirt/dust may have gotten in the sample. No signs of any air filter issues elsewhere.
Below are the results, if anyone sees anything that concerns them, please let me know. This was with 3200 miles on the oil, and 138k on the engine.
iron 55 ppm
chromium 3 ppm
lead 3 ppm
copper 2 ppm
aluminum 9 ppm
silicon 97 ppm
boron 38 ppm
sodium 10 ppm
magnesium 94 ppm
calcium 2480 ppm
phosphorous 1163 ppm
zinc 1358 ppm
molybdenum 7 ppm
tin, nickel, silver, barium, titanium, vanadium, potassium 0 ppm
fuel 1% vol
vis @ 100 C 20. 44 (15w40 castrol, diesel rated)
water 0% vol
soot/solids 0. 2% wt
glycol neg
tbn 5. 7
f-soot 0. 2
Their comments said excessive wear is not indicated, and said nothing else but to change the oil if not done at time of sample.
Any advice on what may be causing the blowby is begged for. After this, I amnot sure if the rings or head gasket or valve guides are the culprits.
1) head gasket
2) turbo seals
3) rings
4) bad injector
iron 55 ppm
chromium 3 ppm
lead 3 ppm
copper 2 ppm
aluminum 9 ppm
silicon 97 ppm
boron 38 ppm
sodium 10 ppm
magnesium 94 ppm
calcium 2480 ppm
zinc 1358 ppm
molybdenum 7 ppm
fuel 1% vol
water 0% vol
glycol neg
tbn 5. 7
f-soot 0. 2
