Check Engine Light
Odd, perhaps dumb parts question
What is book time to replace hydroboost unit?
StanHolder
Got two codes yesterday. PO191 and B2100. Not sure they are related. Truck starts and runs fine. I have a CP3 showing normal charging voltage and fuel pressure. Could it be a sensor. Batteries are optima about 2 years old.
2006 2500 no upgrades
125,000 miles
125,000 miles
I guess I know now why nobody has responded. I took the truck into the shop. He has had it a week and still can't find the problem. The only thing he has said is the filter to the fuel tank is dirty. I do not go mudding but was extremely muddy weekend at the deer lease a few months ago. Fuel pressure is good, alternator is charging and the fuel rail sensor is good.
First things first. Delete the codes and do a hard reset on the electronic, means disconnect the battery's.
Many codes that show and do not impact drive ability are glitches and won't come back.
P0191 - Rail pressure sensor performance/range - if it comes back replace sensor, check wires to ECM for resistance first.
B2100 - Driver door lock switch - very likely broken wire in the door harness, nothing important.
They are not connected to each other.
This would be my starting points - if needed after a reset - here.
I dealt with a PO191 on a 2011 6.7 before. Rail pressure relief valve solved it.
There are many reason that can trigger a P0191, that's why needs to follow the trouble shooting tree to figure ut out.
PRV is only one of several possibilities. I try to keep him from wasting any more money right now.
I agree. Just relaying an experience I personally had to let him know what may be the solution down the road. Not a challenging repair, easier to get to than the rail pressure sender that’s for sure.
