I have had a number of PMs regarding the getrag and how one might diagnose various problems that do occur.
To that end I would like to have as many as possible join in this thread and offer additional advise.
This is what I have suggested to others:
Have you run the transmission with low lube? Always have the extra qt?
After a visual check of the transmission to see if there are obvious external problems, an internal check can be done without opening anything. Use a hard plastic drink cup and while stopped (engine running) and then while driving, touch the (empty) cup to the shift stick knob. The various sounds that the transmission make will be amplified by the megaphone of the cup. You may not know what all you are hearing but what you hear will be loud enough to make a preliminary judgment as to looking deeper. It is helpful to have a 'good' transmission to listen to for reference. Does the sound you notice become greater in a particular gear? ( I can hear the injection pump).
I would note that sounds from a bad ujoint or from the differential can be telegraphed to the stick and cause confusion. These of course will not be heard when stopped.
If you have concern after this brief check, open the side covers on the transmission and look at the gears and syncros. The gears should be mirror bright with no evidence of scuffing what-so-ever. You can see the front portion of the gears QUITE well and with a flashlight and mirror can see the back pretty good.
One of the major causes of failure on the Getrag is the front countershaft bearing. Because of the design of the OD, this bearing is always loaded with the exception of the brief time the transmission is in fourth. If this bearing is worn/failing, the countershaft will show movement fore and aft. You can determine this by prying the countershaft fore and aft. If it moves at all, you have a problem. The countershaft bearings are 'preloaded' and there should be NO decernable movement. Very minor movement may be corrected by resetting the preload. My transmission has 425k miles and has never had a real rebuild but it has been out and reshimmed on three occasions.
From the posts I have read on the fwd trucks, the getrag would require countershaft bearing replacement at a shorter interval than for the twd trucks. The transmission and transfer case are cumbersome and I understand that no one wants to take them out for the fun of it but if the system is maintained according to a pre-need schedule, the getrag will wear the engine out on the fwd without the expense of a 4500 or 5600. The price of a transmission jack is far less than the cost of a 4500. This is probably too long now so will stop.
1stgen4evr
James
1stgen4evr
James
