Ramrod,
Here's the FAQ from the Zoopseal web site:
What is Zoopseal?
Zoopseal is a hybrid ceramic sealer, it is not a polish or wax. It is a protectorate.
What does a ceramic base sealer do?
It will impregnate into the pores of the product being treated, which will stop the process of oxidation immediately. A crisp, and clean appearance is the end result. Your product will continue to look like new without repolishing.
What can I use Zoopseal on?
Aluminum, Raw Aluminum, Brass, Chromed Plating, Stainless Steel, Anodized Aluminum Parts, Stainless Steel in Restaurant Kitchens, Outside Furniture, Awnings, and Paint.
How long does Zoopseal last on my product?
2 to 3 years.
When it is time to re-apply after 2 to 3 years, how and what are the steps?
You will need to re-condition your product if necessary and re-apply (you’ll need to re-order a Zoopseal Kit) using the same method as before. Just follow the Kit instructions and your product will continue to look like new.
Will Zoopseal rejuvenate or refurbish my product?
No, it will not. It will only protect from oxidation and dulling.
Will it harm the painted finishes on my car?
No it will not.
Will Zoopseal provide protection against fresh water?
Yes, but not against underwater abrasions.
What does salt water do to Zoopseal?
We recommend that you do not have your product immerged into salt water for a length of time (over 2 hours). If exposed to salt water use soapy water and wash off the salt within 2 hours. Salt water will cause your product to discolor.
How can I get Zoopseal off my product once it is applied?
By repolishing the product using any commercial polish.
What type of cleaners can be used on Zoopseal?
NO CAUSTIC OR ALKALINE CLEANERS. Only Zoops Cleaner is to be used on the product.
How much Zoopseal do I need on the lint free towel during the application process?
Very little!!! The towel should be barely damp, NOT WET!
Can I use Zoopseal on my radiator and will heat affect it?
Yes, you can use Zoopseal on a radiator. Heat from the radiator will help it to cure and make it stronger. We do not recommend putting Zoopseal on an exhaust, this heats up too much.
Can I use Zoopseal on Magnesium?
No, not yet, it is still being tested.
Can I use Zoopseal on Copper?
No, this has been tested.
Can I use Zoopseal on Fiberglass?
-Jay
