I think I'll be needing a new clutch before too long. I was looking at South Bends' 12 1/4 Con O clutch. Says it'll hold 400HP, 900 lbs. torque. That should be fine; I've only got a Comp box and in the future I'll put in RV275 injectors. The question is, it says that it is not recommended for heavy towing. If I did tow heavy I could always turn the box down or off. Surely that wouldn't jepordize the clutch. Also would it hold up to full throttle lauches? I just don't have the money for the Con OFE. Give me your all suggestions. Thanks
