Code P0336 and P0483 intermittent at same time
5.9L regular vs. High output - How do you tell?
Broken ground strap on 2006 Megacab.
A 2005 Ram 5.9 2500 throws codes P0336 Faulty crankshaft position sensor and P0483 fan speed at the same time. Seems to happen when hitting road bumps. Looked for frayed wire or loose connector, wiggled wires at crankshaft sensor and fan speed sensor connectors. Check engine light went off but went back on went going over bumps. Opened an sprayed fan speed wires connector with dielectric spray, Still have the problem. --- Any suggestions?
After checking and spray cleaning connectors to fan and crankshaft position sensors I replaced the crankshaft position sensor. This solved the problem. It acted like something loose but apparently was the sensor.
