Will be calling ATS tomorrow. I know there are many transmission companies out there but is there any reason to look elsewhere. ATS seems to be a good company?
There are lots of complaints with ATS about their customer service if you have an issue after the sale.
They are also often considered overpriced for the product but not as bad as Banks.
Their new improve 3K/5K kit is pretty darn nice thou! I really like how they have the turbo/intake setup. Underhood temps start to get very high when towing and an open element air filter just decreases turbo performance when you need the most performance out of it.
WOW just input for 10 minutes and lost after I hit wrong button.
I think with twins you will be 450-500. I love my twins.
Water meth will provide lower EGT, Less smoke, more HP, and better mileage.
Exhaust of <5" will increase EGT. I've had 5 to 4 and back to 5. I won't go < 5 ".
You need to determine What stage. I chose stage 5 because I wanted 600 WHP.
Tell ATS that truck would be used for towing as that might be different torque converter. Ask about getting Co Pilot as it limits FULL boost until trans get into lockup, which would help to last longer.
Hope this helps and doesn't confuse!
Twins don't add power, fuel adds power. Just going twins wont do anything for rwhp unless you are overfueled...such as black smoke all the time. You could go from having a good clean running 400 rwhp tune at 1250° to twins with a good clean tuning 400 rwhp tune at 900° if all you do is add twins. Nothing wrong with either tune, one just runs cooler and will do better at altitude.. but the twins don't add power.
Interesting observation on exhaust and defiantly not what most people see. 4" exhaust is plenty for up to 600+ rwhp and 5" is generally considered mostly for show below that area. If a 5" exhaust is making a different at the 450-500rwhp range then something is wrong with 4" setup. I realize you are 600, but even then how much of an EGT difference is it? Just curious.
Do you tow at 600rwhp? If so how often do you use it?
Have you only ever ran the Edge? The Edge products don't run the timing of some of the other setups which leads to more exhaust volume and could make the exhaust more noticeable.
What kind of EGT's are you running to use water meth and twins while towing?
Do you monitor oil temp while towing?
