Hmm, I wonder if C&Cs are different for regen programming, as other components, tune, and configurations are different than P/Us?
We may never know.
Ron
Do any of you ever get an EVIC notice of anything regarding Regen? Neither my 2009 nor my 2017 have ever provided a Regen related messag? When idling in park, the RPM increases a little over 1,000 and lasts several minutes. If it weren't for the RPM change and the CST2 monitor, I wouldn't know it was in regen. Just curious. Ron
Yes Sir! EggsActly right. I noticed this most transporting generators, when the only time I shut truck off was refueling. And the green regen light on the CST2.
Ron
Yes, on the '19+ one of the gauge screens on the EVIC is the DPF status. Normally it indicated percentage restriction. During a regen it indicates it is in progress.(Not my truck, just a google search photo).Do any of you ever get an EVIC notice of anything regarding Regen? Neither my 2009 nor my 2017 have ever provided a Regen related messag? When idling in park, the RPM increases a little over 1,000 and lasts several minutes. If it weren't for the RPM change and the CST2 monitor, I wouldn't know it was in regen. Just curious. Ron
Asian transmission fluid.... I'm sure it's abundant in Thailand.
Makes a lot more sense!
I'm quite certain your truck is also doing the standard 24 hour minimum regens, as your duty cycle likely allows you to not need regens any more frequently unless idling as mentioned.
Looking back to 2007 the 6.7 was released without this idle software. It was stranding farmers, hunters, and others who needed to idle or couldn't get up to speed for a regen. In all honestly it was the main reason I didn't buy an 08 when I picked up my 05 used. The 08 was the a Big Horn vs XLT and otherwise the same, only 1K more new than a used 05 but I wasn't about to get stranded in the back country. Shortly thereafter Dodge came out with TSB 10-013-08 that added Net Zero and Net Reduction idle modes to the 07.5-08 6.7's, and all trucks came programmed that way afterwards. Those titles aren't mentioned much anymore, but if you're at 1050 rpms with the CTS2 green light you're in Net Reduction mode. It's active regen, but SLOW and not the same as a stationary regen (AlfaOBD, Dealer, C&C regen button).
John,
Came up with another theory... my observed regens were the 24 hour ones... no good source info on it, but appears possible. Read posts on Cummins Forum that made me think about the timing of my observations more than load cycle.
BL: My observed regens on the CST2 could very well be the 24hr timer. I feeling did have a mix... had more than a few bad traffic jams that were likely Intervention Regens.
I really like these threads where we get to share info and learn about our trucks, particularly when it's on a subject that Ram provides little or no info on. Saw good info from a poster with an app that clearly showed regen on the 24hr mark. The how to still has question though, some reported part of the software actually artificially increased DPF load to 100%, then ran the regen.
I'm capturing bits and pieces though that leads me to believe there are differences between PU and C&C emissions... FOM: it takes 900 RPM PUs and 1050 RPM for C&Cs to maintain DPF, basically slow or stop DPF loading.
Anhoo, still looking for more shared info on this. Whisked I had this perspective while I was towing heavy generators in traffic and open highway.
Christmas Cheers, Ron
Hey guy's this is from out in the far-left field so, take it for what it is worth!
Do any of you monitor fuel usage during regeneration such as average MPG usage on the display? When my truck would regen and this occurred when towing my 5er about every 250 miles. The average MPG would drop to under 9 MPGS and the EGT's would rise to 1,200 to 1,450F. After regeneration process the fuel mileage would increase and the EGT's would return to normal around 800F. If I was not towing this would occur less often but I would observe the same decrease in fuel mileage and the increase in the EGT's.
I know this is a 2008 truck and Ram has changed the emission program on the newer trucks by going to the SCR emission design. But when the trucks due regen they still need fuel to burn in the DPF. So, I believe if you look at the MPG's on the display also you might see a decrease in fuel mileage along with a rise in EGT'S if you monitor them.
But this all changes sometime around mid-2009 on my truck.
Unfortunately.....I have little to nothing to offer, except for I keep the DEF tank full, and let White Lightning do it’s thing. Since I run commercially, and my device for my ELD gathers some information from the OBD port, I can’t run a splitter and monitor anything with an EDGE unit.I'm hoping Greg Brockman posts his regen experiences... Not trying to hijack the thread, just it's heavily slanted on regen topic.
