If all things go right I will be getting a *ah hum* certain truck for a certain felllow from a certain website. :-laf It's got a gasser,4spd in it. This is all up in the air right now but I'm tossing around my ideas for later on. Thought about after I got it to start looking heavily into a p-pumped motor with either a 5600 or 4500 backing it. Do it all right,studs instead of bolts in head,head gasket,plate,turbos and all that good junk. Back to trans with Southbend clutch,weld fifth gear nut and all that jazz. Thing is I'm wondering if it would be cost effective to do this. OK it's the crew cab that Sam has Oo. It would be my daily driver,towing a trailer probably once every two weeks. Thing it will be towing though would be one hellva trailer. Looking into probably a 35-40ft gooseneck or fifth wheel trailer(which ever is the longest DOT will let you tow without CDLs) with two fullsize four wheel drive trucks. Both would be loaded to the gills with heavy "go to the woods and come back in one piece" parts
:-laf Plus camping gear and that jazz. I was wondering what yall would think would be a ballpark figure price for a good P-pumped motor backed with 4500 trans. Would it be cost effective to put the motor in the truck? I know it would help a little on gas mileage but would be heavier and harder on frontend/driveline parts. Just ideas floating in this little bitty brain that I can't truly answer myself
