Hey guys,
Another issue with the truck is the cruise control. Ive tested all the wiring according to thr wiring manual and brake switch however the wiring from the output speed sensor is not correct according to the wiring manual.
The 2 wires from the output speed sensor on the rear diff are "supposed to" connect directly to the PCM on Connector 2 if i remember correct.
They dont they are actually both a different colour and connect to a connector under drivers wheel arch. At the PCM pins where they are supposed to go there is wires that are correct according to the diagram but between the unknown connector in the wheel arch and the PCM i have no idea where the wires go. Also i cannot get any continuity between them. Only continuity from speed sensor to the first connector not shown on the diagrams.
Cheers
Cheers
