CRUZE CONTROLL
Yet another Recall - Backup Camera
Mirror
Trip to Costco a couple days ago I hit cruze/set and nothing displayed. I tried several times it would not set speed. On the way home I tried again, nothing!
Yesterday trip to RiteAid same thing.
Everything else is working as usual. So any thoughts as to why it's not working?
15 LongHorn DRW
Sounds like something similar my wife's 2015 does/did from time to time. You had to really mash the button and rock your finger on it to get it to come on. I took some canned air and blew around the edge of the button, seems to have cured the issue. Must have gotten some dust on the contacts in the button.
Here is a wild idea check for any codes that have been stored in the ECM. I know that the cruise control will not work if the ABS brake system has a code! I had a bad wheel sensor on the front RH wheel that would throw a code every once in awhile and the cruise would not work. When the code was cleared the cruise would start working again.
Just a thought!
Had the same thing happen, it would show the cruise icon, but when I pushed set it would not active or turn green.
Was on the way to Montana, called ahead, and got into dealer in Idaho, and it was just a flash or reset of some kind ,nothing mechanical or anything needing replaced . Took less then an hour. I was still on warranty.
When you push the on, off button does the cruise icon appear in the lower right hand corner of the screen, but will not turn green ,and activate the cruise when the set button is pushed ?? If so it sounds like whatever mine was doing .
Nothing lights up at all.
I’m guessing trip to dealer. I have MaxCare so it should be covered.
Only bad thing is I don’t want the drag link welded.
As mentioned I have no idea how to check codes.
No icon in the the lower right ,or telling you cruise is activated ???? Different then what mine did, it just wouldn't set ,and turn the icon green .
Last time at a dealer ,I had to tell them to leave the drag link alone, they had no problem with that, and did the other recall I did want .
15 LongHorn DRW
I’ve had to replace the cruise button switch assy on my 2015 and 2018. Believe me, that’s your problem. If my local dealer keeps the part in stock it’s a very common failure item (they had 5).
You are correct! I was just hoping for a real fix. I had my truck aligned 50k back and the tires are still wearing great. So I guess it does not matter as I don't plan to get another alignment unless front end parts are replaced.
Mine was replaced under warranty back in 2016, and a year later it started acting up again. My temp fix is to do a medium thump of the steering wheel with my hand and it will start working again (sometimes 2 or 3 thumps). This usually fixes it for 15 to 20 starts, then it needs another thump.
