Dana 80 Diff. Gasket#
Fuel = Heating oil
Help!!!! I have been running around town looking for a gasket for my 97' 3500 Dana 80 rear end, no one in town can seem to find the right part number. Can anyone help?
Thanks
Rory
97' 3500 CC 4x2
Cummins,TSTed Auto, Bright
White / Spruce  Int.
RoryTek,
The Dana 80 does not require a gasket.
A 1/4" bead of a good oil resistant sealent( Permetex Ultra Blue works great) on the cover sealing surface is all thats required. Apply around the bolt holes like in the picture. Let it set up for 15 mins.
30-35 Ft Lbs torque on the bolts.
(picture found @ Fritz`s web page)
Bill R
94 2500 SLT 4x4 5 Speed, 3. 54 LS, JRE 4" exhaust, Autometer Pyro, Boost & Water temp gauges, Bosch 215 HP injectors, Timing @ 14. 7 º, JRE Stage III #4 plate 270/675, AFC spring kit, Scotty Air, Bully Dog Propane Injection, Roadmaster Active Suspension, Optima Red Tops, Geno`s Exhaust Blanket,Espar Heater (won it!), Synthetic lubes throughout.
[This message has been edited by HEMI®Dart (edited 09-17-2000). ]
Permatex " Right Stuff " works good also. It is available at NAPA in a tube or a cheese-wiz type can.
Paul A. Schmidt
95, 4X4, SLT 2500, 5 spd. , 4. 10, 270 hp. ,675ft. lb. TST, AFC spring kit,215hp. injectors,16cm2 turbo housing, Pacbrake, Walker muffler,
GearVendor O. D. , CenterForce Dual Friction clutch.
Eastern PA.
When I change my rear end I got a armored(gasket with metal samwitched in between) gasket from Big A. I wish I could give you a part number but it's been too long ago.
I have changed mine 3 times already. Used Permatex "Oranage" high temp. I think most all will work as long as you get a good clean surface (brake clean) first.
No gasket is needed.
jjw
Use orange -or blue-or out in the middle of now where clear -white -bath tub siclone caulk( shade tree )sealer works the same. Used on fuller transmissions back in the early 70s heat is not a proplem. They had to add color for the automitive application.
96-3500 SLT EXT. CAB AM/FM/CD-RINO LINER. D-CELERATOR EXH. BRK-RED LINE VAC. OVER HYD BRK CONTROL- AIR BAGS W/HVY DUTY AIR COMP. PUTCO S/STEEL DEEPBOARDS FRONT TO REAR. REESE 20K 5TH WHEEL & GOOSE -REESE 20K HITCH BELOW W/17K RECEVER. CLEAR COATED & SOUND DEADINGING &UNDER COATED 5 SPD/W 4:10 MCHLN'S 235/16'S UNIDEN PC76/WEATHER-WILSON 1000 MAG MOUNT ANT. 4 WHL ANTI LOC BRK SYS.
